000Nyk/Skoda S135 MPI 000Nyk/Skoda S135 MPI
komentáře | popis | fotky | nyk23 | 03.05.24 23:31 | 115x v oblíbených
Skoda S100-1975 , I am the second owner!
Engine-781.135M -AMG with ECU Felicia 50kw only for spark, and Skoda Favorit intake manifold with carburetor adapter from SP-EL.cz and Skoda 135 carburetor, runs very,very,very well :)
Increased compression ratio, two springs on the valve, cylinder head porting
Felicia starter with reducer
Gearbox 5 speed- 3.90 with back system from Rapid 130.
Brakes: Front all system from Rapid 130 with 4 pistons, Back Caliper VW with pads, disc VW polo
All of the wheel hubs modified to 4X100 PCD
Springs: back Koni spring yellow from 130LR - front original 130L(soft springs)
Shocks: back Bilstein gas Ford Escort Cosworth(Minor modification) - front Mitsubishi Pajero 3.0 V6 with hardness adjustment
Exhaust: Citroen C1 modified (So it sounds like stock)
Wheels: KN Diamond 14x6J PCD 4x100 Made in England very light wheels (Same manufacturer as original Skoda alloy wheels)
Tires: front and back - 165/70/14
I don't understand Czech. Please write in English.
000Nyk/Skoda S135 MPI - komentáře:
06:08:50
11.02.2016
11mAjA11
According to my information You can swap that ECUs without any other HW changes.
It has only software differences.
Just re-code immo and it must working well.
4 4 4 4
20:34:43
09.02.2016
11mAjA11
If it is possible send me complete number from that ECUs I can ask one of my frine who works in Česana (Škoda Auto - electric department) maybe he can help in this case.
Or take a picture of stickers from both of them, it will be sufficient.
4 4 4
20:12:31
07.02.2016
nyk23
Do you know the difference between ECU 40kw and ECU 50kw from Skoda Felicia? Is a difference between them? Or difference is the engine only. Thanks in advance!
09:48:36
15.11.2015
krtik
23:04:02
14.11.2015
22:52:12
14.11.2015
krtik
-> nyk23 14.11.15 22:23:19: I think, this headlight glass isn't manufactured. But someone grinded this from original glass. Maybe you will find some manufacturer or someone, who know make this from original glass 6.
22:23:19
14.11.2015
nyk23
Can someone help me to purchase two clear glass headlamp Skoda Felicia 98! like this...
img.skoda-virt.cz/vase_au ta_upload/.../1975_2007-11 -24_12-09-07_49.jpg
upraveno 1x, naposled 14.11.2015 22:25:48
07:44:39
10.02.2014
-> U-Geen: Kamarad mel na aute oboji a Brembo pry nebe a dudy. Podobne receze jde najit i na webu.
upraveno 1x, naposled 10.02.2014 07:45:17
00:24:15
10.02.2014
-> Tuner#2: proc? ja jsem byl s PowerDiscem spokojenej
01:18:14
09.02.2014
-> Janeon 09.02.14 01:11:32: Klasika ATE powerdisc, ale kvalita nic moc. Pokud chceš mermomocí drážky, tak Brembo Max.
01:11:32
09.02.2014
Janeon
z ceho ma ty drazkovane kotouce? nebo spis jaka firma? vzdycky jsem nasel s dirama:/
22:17:35
25.01.2014
nyk23
My flywheel is from Felicia 1.9D. Wondering if you go put on gearbox skoda rapid.
Cheers!
10:06:19
25.01.2014
rubajz
-> nyk23: you can switch motor starter only between škoda felicia 1.3 and 1.6, felicia 1.9 has another, inside bigger
21:04:19
12.12.2013
nyk23
Are called Smoor Roadster 13'' 7j front, 8j back with tires 175.50.13 all.
Front et 14, back et 4.
upraveno 1x, naposled 15.12.2013 14:15:02
12:42:58
11.12.2013
What wheels did you purchase and what is the pattern? It's nice :)
23:32:36
28.04.2013
nyk23
ie can switch between them from Skoda felicia mpi to another skoda 1.9D?
upraveno 1x, naposled 28.04.2013 23:35:42
23:30:09
28.04.2013
nyk23
if you go from 1.3 to 1.9D (starter engine)www.aes.nl/WebRoot/.../15 .130.0062.jpg
