Skoda S100-1975 , I am the second owner!
Engine-781.135M -AMG with ECU Felicia 50kw only for spark, and Skoda Favorit intake manifold with carburetor adapter from SP-EL.cz and Skoda 135 carburetor, runs very,very,very well :)
Increased compression ratio, two springs on the valve, cylinder head porting
Felicia starter with reducer
Gearbox 5 speed- 3.90 with back system from Rapid 130.
Brakes: Front all system from Rapid 130 with 4 pistons, Back Caliper VW with pads, disc VW polo
All of the wheel hubs modified to 4X100 PCD
Springs: back Koni spring yellow from 130LR - front original 130L(soft springs)
Shocks: back Bilstein gas Ford Escort Cosworth(Minor modification) - front Mitsubishi Pajero 3.0 V6 with hardness adjustment
Exhaust: Citroen C1 modified (So it sounds like stock)
Wheels: KN Diamond 14x6J PCD 4x100 Made in England very light wheels (Same manufacturer as original Skoda alloy wheels)
Tires: front and back - 165/70/14
I don't understand Czech. Please write in English.
000Nyk/Skoda S135 MPI - komentáře:
11:06:03
20.08.2007
20.08.2007
nyk23
Hi Gogata BG!!I am glad you like my skoda.Maybe i'll go in Ruse to buy some sphare parts
10:47:24
20.08.2007
20.08.2007
Gogata BG
Nice to see you here, az I told you in Skoda Club Bulgaria forum - great car! Best wishes!
10:13:47
10.08.2007
10.08.2007
nyk23
Hi! I plan to go in Czech Republic to buy some sphare parts from my S and Rapid.I ask u where find a good market to buy some sphare parts.It's very good if u give me adress where find market beacouse try to find for gps. Thanks!!
00:08:13
27.04.2007
27.04.2007
pistaa
-> nyk23:
MOc moc pekne avto drzim palce
22:02:57
02.11.2006
02.11.2006
Matty110L - zrušená registrace
New photo please...very nice car!!I like skoda 110....
21:12:36
02.11.2006
02.11.2006
nyk23
Thank you very much gim!!
09:44:41
02.11.2006
02.11.2006
gim
-> nyk23:
how to make dumpers harder.
In S120 front dumpers is 100ml oil and in rear dumpers is 110ml. Old oil what you had emptyed, or buy new one special dumper oil. (it´s strange sentence in czech- maybe it means to use it but i don´t know). I used hydraulic one type OTHP-3, it´s compact, quite heat standing and it isn´t bubbleing.
I hope its true translation :-)
00:04:20
01.11.2006
01.11.2006
nyk23
Someone translate to english please!
Jak přitvrdit seriové tlumiče
Ve stodvácových předních tlumičích je 100ml oleje a v zadních 110ml. Olej buď starý, co jste vylili nebo koupit orig. tlumičový. Já jsem používal hydraulický OTHP-3 je husší, tepelně relativně stálý a nepění
19:30:24
24.10.2006
24.10.2006
nyk23
Thank you!
20:46:34
23.10.2006
23.10.2006
gim
-> nyk23:
zadní náprava- rear axle
druh kyvadlová- swing axle (like S100L original)
sbíhavost- toe-in (sth about wheel position)
23:13:47
22.10.2006
22.10.2006
nyk23
Zadní náprava
Druh kyvadlová
Sbíhavost 0 mm +2 -1
Zadní náprava
Druh kyvadlová
14:02:50
22.06.2006
22.06.2006
janos
-> nyk23: "Prodam kola bmw 17'' - WOW, your Czech is much more better than my Romanian
Wish you good luck. Personally, I prefer factory look more than tuning look but I have to admit you are very brave and patient to search for tuning spare parts in Romania, far from Skodas´ home country...
16:22:03
20.06.2006
20.06.2006
nyk23
Hi janos!!It,s not a 4 last
It's very much Skoda car in Romania but most people no spend money for tuning.All people buy sphare parts for car to go normaly....not speed,raly,drifting,etc.
About sphare parts-it's hard to find sphare parts for tuning:discs ventilated,brake pads,weels,engine parts:pistons,chamshaft.. ..
Now i try to find wheels very light 8jx14''-front; 9jx14''-back for my Skoda
and very hard to find.Probably original steel wheels 14''skoda...go to modification,it's single option for the moment.Prodam kola bmw 17''
Good luck skoda friends!!
15:53:59
20.06.2006
20.06.2006
nyk23
Hello Tuxik!thanks for your wish
14:56:49
20.06.2006
20.06.2006
janos
Hello Nyk, congrats, you have quite a nice car... BTW, are you able to estimate how many Skodas are in Romania nowadays? Last photo says there´re at least four ones
How´bout the spare parts? Is it difficult to get ´em?
13:29:33
20.06.2006
20.06.2006
Tuxik
nice car :-) i like oldtimer skoda car :) i wish you a lot of kilometers without crash !
16:57:07
19.06.2006
19.06.2006
Luukkyy
-> nyk23: Great car :-) Thank for photos!!!!
19:46:52
14.06.2006
14.06.2006
nyk23
Thanks!!
12:05:57
11.06.2006
11.06.2006
Good car!!Let´s go!!!
15:09:36
10.06.2006
10.06.2006
nyk23
I don't have foto from Castle Dracula.You must come here to see live this castle.The gas it,s 1,15Euro/L- OMV Super100.
so if you come some sphare parts from skoda it,s very good
Good help!
