S136R (šedý II)- mam ho od roku 2000; dilci renovace a upgrady: 2004, 2009, 2015-2017
cilovy stav je uplne renovovane auto, pri vyuziti drobnych uprav motoru, podvozku a elektriky, vzhledove jen malo odlisne od originalu.
Rad si obcas projedu nejaky horsky prusmyk nebo vyjdeu na kopec (pokud mozno nad 2500m), maly seznam:
Alpy:
1 GrossGlockner - Hochtor 2550m (Rakousko, 2006, 2019)
2 Passo Resia 1508m (Italie, 2007, 2010, 2011, 2019, 2021)
3 Passo Stelvio 2750m (Italie, 2007, 2009, 2010, 2011, 2019, 2021, 2025 (2.5x) )
4 Passo Gavia 2640m (Italie, 2007, 2019)
5 Simplonpass 2005m (Svycarsko-Italie, 2007, 2011)
6 Furkapass 2436m (Svycarsko, 2007)
7 Oberalppass 2046m (Svycarsko, 2007)
8 Passo piccolo san Bernardo 2188m (Francie, 2008, 2010, 2011)
9 Passo grande san Bernardo 2423m (Svycarsko-Francie, 2010, 2011)
10 Col de'l Iseran 2770m (Francie, 2008, 2010)
11 Col du Galibier 2645m (Francie, 2008,2009)
12 Col du Vars 2111m (Francie, 2008, 2011, 2021, 2024 (2×))
13 Cima de la Bonette 2802m (Francie, 2008, 2011, 2021, 2025)
14 Passo Rombo 2503m (Rakousko,Italie, 2009)
15 Col de'l Izoard 2344m (Francie, 2009, 2021, 2025)
16 Umbrailpass 2503m (Italie-Svycarsko, 2010)
17 Passo dello Splungo 2118m (Italie-Svycarsko, 2010, 2011)
18 Nufenenpass 2478m (Svycarsko, 2010)
19 Col de la Croix du Fer 2068m (Francie, 2010)
20 Passo S. Bernardino 2065m (Svycarsko, 2011)
21 Passo Torre di Fraele 1800m (Italie, 2011)
22 Passo di Foscagno 2291m (Italie, 2011)
23 Passo Bernina 2328m (Svycarsko, 2011)
24 Livigno Pass 2315m (Italie-Svycarsko, 2011)
25 Montgenevre 1854m (Francie, 2011, 2021, 2024)
26 Passo Sella 2218m (Italie, 2019)
27 Passo Pordoi 2239m (talie, 2019)
28 Passo Falzarego 2105m (Italie, 2019)
29 Col d'Allos 2250m (Francie, 2021)
30 Colle della Maddalena/Col de Larche 1996m (Fr-It, 2021, 2024, 2025)
31 Col de la Cayolle 2326m (Francie, 2024)
32 Col de la Machine 1011m + Combe Laval (Francie, 2024)
33 Col Agnel 2744m (Fr-It, 2025)
34 Col de la Lombarde 2350m (Fr-It, 2025)
ToDo:
prio 1:
Alta via del sale (Italie)
prio 2:
Flüela Pass (Svycarsko, 2383 m)
Albula Pass (Svycarsko, 2312 m)
Grimsel Pass (Svycarsko, 2164 m)
Ostatni:
1 Veleta 2600m (az nahoru se vyjet neda) (Sierra Nevada, Spanelsko, 2010)
2 Pas de La Casa 2400m (Pyreneje, Andorra, 2009)
3 Col d'Aspin 1489m (Pyreneje, Francie, 2011)
4 Col du Tourmalet 2115m (Pyreneje, Francie, 2011)
5 Port de Boucharo 2270m (Pyreneje, Francie-Spanelsko, 2011) az nahoru vyjet nejde, zavalena cesta
6 Col du Soulor 1474m (Pyrenje, Francie, 2011)
7 Col du Aubisque 1709m (Pyreneje, Francie, 2011)
8 Col du Pourtalet 1794m (Pyreneje, Francie-Spanelsko, 2011)
9 Transfăgărășan 2042m (Făgărăș, Rumunsko, 2022, 2023)
10 Pasul Urdele 2145m (Capatanei, Rumunsko, 2022)
ToDo:
Pikes Peak (USA-CO, 4301 m) :D
Stav:
-> Pohon
--> Motor 1.5 (druha verze od MEXu 2009 po repasi 2015), olejovy chladic (MOCAL, 115mm 34 rad.) plus termostat
--> spojka SACHS s lamelou z TAZ1500 (109-150111, 441 270 532 529).
--> ventilator dochlazovani SPAL, trochu mne zklamal, ale nejak to chladi
--> Karburator revize C:
----> komora 25/28 udelana ze zakladu 23/27.
----> hlavni systemy: I st. 140/180, II. st. 160/140. II. st.
----> prechod/volnobeh: I. st. 50, II. st. 70
----> viko SEDR T613, ventil 2mm
----> sytic (tlumitko, tycka, kluisa) dle originalu SEDR T613, tryska 145
--> mereni teploty oleje a vody ridici jednotkou (presnost +-1 st.), sensor domaci vyroby s termistorem EPCOS (kalibrovano)
--> indikace tlaku oleje (VDO set - snimac 10bar + klasicky indikacni budik, presnost +- bota)
--> lpg na hrani a levnejsi jezdeni (1998,2009,2020)
--> upravene sani s implementovanou upravenou starsi verzi mixu pro fel 1.3 (viz. foto)
---> snizeni zastavbove vysky
---> lepsi provoz na beno a hlavne bez der, zpusobenych virenim za puvodnim mixem
---> vestaven delsi vzduchovy filtr z Fiatu Doblo 1.4JTD? (3C1-18900, C 1189 (Mann) )
--> vestaveny modul pro prubezne mereni bohatosti sirokopasmovou LS (Bosh LSU4.2)
--> elektronicka ridici jednotka zapalovani BTZ-III (2007)
-> Podvozek
2004:
--> nova zadni naprava, vyztuzena nova podelna ramena, nova sikma ramena, nove silentbloky, nova pricka
2008:
--> nove kloubove hridele
2009:
--> Predni naprava s chlazenymi kotouci (Saky) a pruzinami 260mm (od PJ) (2009)
2020:
--> Vymena kotoucu - opet za Sakyho typ (upravce wena), vyreseneo zahadne mlaceni
--> Vymena naboju a prednich lozisek
2021:
--> Vymena zadni napravy
--->Osazena puvodni ramena sikma i podelna a pricka (demontovano 2004), podelna vyztuzena, pricka ovarena
--->Nove tlumice (Monroe z sedeho I po 21 letech demontovany)
--->Loziska 21306 (+spacer) a NU205
--->Hridele Kalmar
--->Nove silentbloky
2022:
--> Instalovany unasece kol od paja120
-> vicemene nova prevodovka 5q/3.9 a prislusenstvi (2004, 2009, 2015)
--> servis a serizeni (Wena, 5/2024)
-> Elektro
--> Zastavba BlueTooth gatewaye, k jednotce je mozno se pripojit pres BT z notebooku nebo telefonu (SPP)
--> Elektronizovany pristrojovy stit (krom tachometru - je v planu) (2010)
--> Renovace/vymena predni casti svazku
--> Predratovani hlavnich napajecich vodicu
--> Pridavna pojistkova skrinka na baterii (pritomnost nejistenych dratu vedoucich vsude mozne mne stavala)
--> Doplneno silove jisteni sarteru a alternatoru
-> Karoserie
--> nove zadni okno tonovane na cca 50% nakovenim, bocni na 30% (2007)
--> vymenene predni blatniky (2004, 2016)
--> novy lak 1305 - barva + bezbarvy lak (2004)
--> novy lak 1305 - barva + bezbarvy lak (2017)
--> vymena stropnice (2017)
Poznamkovnik (naplne, spotrebni material, netypicke dily):
Maziva a jiné materiály:
- predni kola SKF LGWA 2
- zadni kola SKF LGWA 2
- svislaky Mogul A00
- vodni cerpadlo SKF LGHP 2
- homokinetaky Millers Hi Mol 20
- motor:
-- Millers Oils NANODRIVE - CFS 10W-60 NT+ (6/2026; 10/2024; 4/2023)
-- Lozisko v klice SKF LGHB 2
- prevodovka:
-- Castrol Syntrans Transaxle 75W-90 (Novy od: 2024, 2017), doplneno 6/2023 2dl
- chladici kapalina G12+
- brzdovka DOT 4 ATE 200 (5/2025)
- brzdy predek - Ferodo Ds2500
- brzdy zadek - Renovak beral
- vzduchovy filtr (longbox) MANN C 1189
- spojkova lamela TAZ1500 (109-150111, 441 270 532 529)
- spojkove lozisko SACHS (02) 3151 812 001
- chladic oleje MOCAL, 115mm 34 rad.
- termostat oleje MOCAL OT/2G
- ventilator dochlazovani vody VA02-AP70/LL-52A
- snimac tlaku oleje 443429021000 Tatra - snad ekvivalent VDO 360-081-030-004C
- indikator tlaku oleje VDO-350010014K
- snimac teploty oleje pro VDO indikátor - interní kalibrační označení 12
- civka Pertronix 60103 (0.3 Ohm, 2.6mH, 60kV)
- pneumatiky: Dunlop Sport Classic 185/70 R13
- palivove hadice dle spec. SAE 30R9
/* - neaktualni -
motor:
-- Castrol Edge TITANIUM FST 10W-60 (6/2021)
-- snimac tlaku oleje VDO 360-023 (0-10bar) + indikator tlaku oleje VDO-350-108 (0-10bar, stupnice PSI) demontaz 6/2023
-- Karburator A: 23.5/26.5 I. st. 130/180 II. st. 160/140 - slouzi jako zalozni nouzovy
-- Karburator B: 26/28 mm z polotovaru 22/24. Puvodne I. st. 130/160 II. st. 155/140. (nasazuje bohate pak prilis chudne) Nalsedne II. st. 145/120. Prechodove/volnobezne trysky lehce zvetseny, prumer neznamy.
- Karburator D: komora 23/27 (T-613 bez uprav). I.st 130/180/50 2st. 155/140/60
predni naprava:
- brzdy predek - Ferodo Ds2500 /* "Renovak" */
Zadni naprava:
- vnitrni lozisko 22205 (zkraceny naboj u kloubu o 3mm)
- pneumatiky: Continental EcoContact 3 185/70 R13
Alpy:
ToDo:
prio 1:
prio 2:
Ostatni:
ToDo:
Stav:
-> Pohon
-> Podvozek
2004:
2008:
2009:
2020:
2021:
--->Hridele Kalmar
2022:
-> Elektro
-> Karoserie
- motor:
- prevodovka:
/* - neaktualni -
motor:
predni naprava:
Zadni naprava:
COL/S136R - komentáře:
23:06:21
26.09.2011
26.09.2011
COL
Prumsyk passo Bernina, jine fotky na tomhle poci nemam.
23:04:57
26.09.2011
26.09.2011
COL
Jeste obrazek z hraze jezera Lago di Giacomo, hned pod nim je Lago di Cancano, oboji je kolem 2km na morem a kolem vede nezpevnena prasna cesta, bohuzel nebyl cas to objet cele. Kus dal je pak take asi nezpevneny prusmyk do Livigna, ale ten je asi prujezdny jen pro cyklisty.
22:46:08
26.09.2011
26.09.2011
COL
-> minno: dekuji
-> Tuner#2: Ale jo, maka +- stale stejne (asi i dobre), ale nejak to neni porad ono :-). Ale nevim moc, co dal, to zniceny soukoli v prevodovce mne trochu zaskocilo. Budu muset zjistit, cim to bylo, rozhodne drive, nez bych uvazoval o necem s vetsim tocakem. Preci jen ta soukoli se spatne shani, zatim jsem ani funglovku 3.9 nesehnal, jen 4.22.... Radeji bych snad, aby to soukoli bylo odesle v dusledku toho, ze jeho montaz tehdy Sixta zpackal... ale to neni zatim jiste.
Takze motor snad OK, neco v nem lehce cvaka, nekde jsem to tu popisoval. Ukazoval jsem to Cepkovi, ten rikal, ze by to kvuli tomu nerozebiral. Zatim se bud nezhorsilo, nebo se tomu moje ucho prizpusobilo a zhorseni neslysi. Muj subj. dojem je, ze to dela nejaka cast rozvodu, ale co, to netusim. Puvodni 1.5 od Chovance pak delala neco podobneho take, take jsem nezjistil, co to je a take jsem k tomu zakladal temata :-). Ta navic, generovala na olejovem vicku obcas takovy zlaty povlak, jako by se vydiralo nejake kluzne lozisko, ale to delala v podstate furt do odstaveni na revizi (ke ktere zatim nedoslo) odjela 65tkm.
Mozna bych k motoru poridil nejaky vykovy system od ME, jestli je zas zacnou delat a budou ochotny to naohybat trochu jinak, nez mi ukazovali na fotce, protoze to mi a) jde do olejovyho chladice, b) se mi nelibi, ze to maji nad urovni plechu, kterej tam neni, ja tam nejaky, byt praveny chci.
15:50:56
26.09.2011
26.09.2011
-> COL 23.09.11 01:19:00: Parádní výlet, smekám. Co 1,5 pořád maká jak má?
15:20:50
26.09.2011
26.09.2011
-> COL 23.09.11 01:19:00: paráda chlape, závidím :)
01:19:00
23.09.2011
23.09.2011
COL
Iti 2011:
1. Budejovice - Passo Resia - Solda
2. Solda - Solda
3. Solda - Passo Stelvio - Passo Torre di Fraele - Passo di Foscagno - Livigno
4. Livigno - Passo Bernina - St. Moritz - Malojapass - Chiavenna - Passo dello Splugo - Passo san Bernardino - Locarno
5. Locarno - Olgia - Simplonpass - Brig - Martigny - Col du Grand St. Bernard - Aosta
6. Aosta - la Thuile - Col du Petit St. Bernard - Albertville - Avignon
7. Avignon - Avignon
8. Avignon - Toulouse
9. Toulouse - Arreau - Col d'Aspin - Col du Tourmalet - Gavarnie - Porto de Boucharo - Lourdes - Col du Soulor - Col d' Aubisque - Col du Pourtalet - Huesca
10. Huesca - Zarragoza - Barcelona - Narbonne
11. Narbonne - Narbonne
12. Narbonne - St. Tropez (Port Grimaud)
13. St. Tropez (Port Grimaud) - St. Tropez (l'Escalet)
14. St. Tropez (l'Escalet) - St. Tropez (l'Escalet)
15. St. Tropez (l'Escalet) - Nice - St. Sauveur sur Tinne - Col des Granges - Cime de la Bonette - Col de Restefond - Col de Vars - Briancon - Montgenevre - Susa - Torino - Novara - Brescia - Bolzano - Brixen
16. Brixen - Innsbruck - GaPa - Mnichov - Rezno - Plzen - Praha
2. Solda - Solda
01:48:05
31.10.2010
31.10.2010
COL
-> palinator: lesk celkem ujde, ale jestli koukas na ty prvni fotky, tak ty jsou pul roku po laku :o).
Bezbravy lak pres pro to, ze mi kdosi tvrdil, ze to je pak vic leskle a lesk vydrzi dele, coz se povrdilo.
Novy lak pro to, ze se objevila nejaka pocinajici koroze u ramu oken, zatim je schovana pod tesnenim a klasicky u spoju predni blatnik sloupek a obavam, ze to nikdo nedokaze opravit tak, aby rozdil barev nebyl videt. Navic je otazka zda budou schopni trefit barvu. to nove predni celo borec meril masinkou a ve vysledku nastrikal barvu u niz pozna rozdil i slepej
. Zatim se to snazim odkladat. lak stal asi 25.000 nekdy v roce 2004, ale borec to celkem odflaknul proti tomu, co nasliboval, takze jsem s nim nebyl spokojen.
. Zatim se to snazim odkladat. lak stal asi 25.000 nekdy v roce 2004, ale borec to celkem odflaknul proti tomu, co nasliboval, takze jsem s nim nebyl spokojen.12:26:22
25.10.2010
25.10.2010
Proč chceš dělat zase nový lak, když je 6 let starý? Kolik vlastně tehdá stál? Proč je přes to bezbarvej? Leskne se jak blázen, líbí se mi to a ta high-tech technika...
Jde do oblíbených.
Jde do oblíbených.
22:18:32
16.09.2010
16.09.2010
VeTeV
-> COL: pecka pane
23:56:48
13.09.2010
13.09.2010
COL
-> minno: -> haso: Dekuji ......
23:14:17
09.09.2010
09.09.2010
-> COL 09.09.10 00:40:58: jeeeee
00:46:35
09.09.2010
09.09.2010
-> COL:
parada parada, ja poznam len tu cestu Zurich, Lindau, Munchen, atd
00:40:58
09.09.2010
09.09.2010
COL
Trasa 2010:
1. Pha - Rozvadov - Mnichov - GaPa - Landeck - Passo Resia (1508) - Passo Stelvio (2757) - Umbrailpass (2503) - Zernez
2. Zernez - St. Moritz - Chiavenna - Passo dello Splungo (2118) - Bellinzona - Nufenenpass (2478) - Fiesch
3. Fiesch - Martigny - Col du Gran st. Bernard (2473) - Courmayeur - Col du Petit st. Bernard (2188) - Col de L'Iseran (2770) - Lanslevillard
4. Lanslevillard - St. Jean - Col de la Croix du Fer (2068) - Col du Glandon (1951) - Grenoble - Valence - Avignon
5. Avignon - Narbonne - Barcelona - Zaragoza
6. Zaragoza - Madrid
7. Madrid-Madrid
8. Madrid - Toledo - Granada
9. Granada - Veleta (parkoviste 2600m) - Malaga
10. Malaga - Gibraltar - Tarifa - Malaga - Adra
11. Adra - Alicante - Peniscola - Barcelona
12. Barcelona - Narbonne - Avignon
13. Avignon - Grenoble - Albertville - Chamonix - Martigny - Bern - Zurich
14. Zurich - Lindau - Mnichov - Rozvadov - Praha
7350 km
Trasa 2009
1. Pha - Budejovice - Dvoriste - Slazburg - Innsbruck - Passo Rombo (2501) - Latsch?
2. Latsh? - Passo Stelvio (2757) - Bormio - Sondrio - Milano - Torino - Bornodecchia - Tunel de Frejus - Col du Galibier (2645)
3. Col du Galibier (2645) - Briancon - Col d' Izoard - Chorges - Valserres - Aix en Provence - Avignon
4. Avignon - Narbonne - Carcassonne
5. Carcassonne - Lastours - Carcassonne - Pas de la Casa (2400) - Andorra
6. Andorra la Vella - LLeida - Vallmoll - Tarragona - Benicarlo
7. Benicarlo - Valencia - Alicante - Benidorm - La Nucia - ?
8. ? - Valencia - Benicarlo -Tarragona
9. Tarragona - Barcelona - Perpignan
10. Perpignan - Narbonne - Le Muy - Port Grimaud
11. Port Grimaud - Ramatuelle - Cap Camarat L' Escalet - St. Tropez - L' Escalet
12. L'Escalet - Ramatuelle - Plage de Tahiti - St. Maxime - Frejus - Ventimiglia - Alessandria - Piacenza - Brescia - Brennero - Innsbruck - Kufstein
13. Kufstein - Innsbruck - Budejovice - Praha
hmm. je tezke si vzpomenout, pocet dni mi zatim nevychazi....
cca 6500km
Trasa 2008, priblizne :o)
Praha - Budejovice - Salzburg - Innsbruck - Bolzano
Bolzano - Milano - Cervina - Villefranche
Villefranche - Courmayeur - Col du Pettit St. Bernard (2188m) - Col de L'Iseran (2770) - Modane - Col du Galibier (2645m) - Col du Lautaret (2058m) - Chantemerle
Chantemerle - Col du Lautaret (2058m) - la Grave - Col du Lautaret - Briancon - Guillestre - Col de Vars (2111m) - Jausiers - Cime de la Bonnette (2802m) - Jausiers - Barcelonnette - les Thuiles
les Thuiles - Tallard - Aix en Provence - Les Baux - Avignon
Avignon - Tarascon - Aigues Mortes - Montpelier - Agde
Agde - Beziers - Monpelier - Arles - Le Muy - Port Grimaud - St. Tropez - Port Grimaud
Port Grimaud - Ventimiglia - Janov - La Spezia - Pisa
Pisa - Firenze (Florencie)
Firenze - Bolzano
Bolzano - Innsbruck - Mnichov - Rozvadov - Praha
7. Madrid-Madrid
7350 km
Trasa 2009
cca 6500km
Firenze - Bolzano
00:35:37
10.01.2010
10.01.2010
COL
-> gabo000000: no, tu uz mam asi 5 let :o)
00:34:41
10.01.2010
10.01.2010
COL
-> minno: Jasne, takove cestovani je perfektni, mam to rad, ale chtelo by to vyrazit jeste nekam dal, ale zatim nejaky konkretni velky plan nemam. Akorat by to chtelo sponzora :o/.
p.s.: Mas hezky fotky z Itosky.
Lak jeste ujde, ikdyz to neni co byvalo, ale potiz je v tom, ze vylezl kvitek u spary blatniku a taky trosku zlobi ram zadniho okna, coz jsem v lete zjistil, kdyz jsem zkoumal, jak to vypada pod tesnenim. Mozna udelam jen lokalni opravu a celolak o rok pozdeji, uvidim.
00:28:45
10.01.2010
10.01.2010
COL
-> Majklsto: dekuji, jeste bych sem mel dat fotky toho pristrojoveho stitu, no ale vlastne ma temer seriovy vzhled. :o)
13:53:03
08.01.2010
08.01.2010
Labros
-> gabo000000: hodně hodně dlouho ji má
23:17:59
07.01.2010
07.01.2010
-> COL: som ani nevedel ze ty tu mas kartu auta...a co teraz vidim...panecku..klobuk dole chlape
21:26:33
07.01.2010
07.01.2010
-> COL: človeče, tie cesty autom sú fantastické, fandím ti :-) Aj ja sa dúfam tento rok znova niekde vyberiem na diaľku, úplne si ma tým teraz znova nalákal :) A čo lak? Dočítal som sa, že máš v pláne nový celolak. Čo je na tomto súčasnom zlé?
18:08:58
07.01.2010
07.01.2010
Majklsto
-> COL: mas to prefektne premakane, hlavne ta aplikacia elektroniky sa mi paci
COL/S136R
