S136R (šedý II)- mam ho od roku 2000; dilci renovace a upgrady: 2004, 2009, 2015-2017
cilovy stav je uplne renovovane auto, pri vyuziti drobnych uprav motoru, podvozku a elektriky, vzhledove jen malo odlisne od originalu.
Rad si obcas projedu nejaky horsky prusmyk nebo vyjdeu na kopec (pokud mozno nad 2500m), maly seznam:
Alpy:
1 GrossGlockner - Hochtor 2550m (Rakousko, 2006, 2019)
2 Passo Resia 1508m (Italie, 2007, 2010, 2011, 2019, 2021)
3 Passo Stelvio 2750m (Italie, 2007, 2009, 2010, 2011, 2019, 2021, 2025 (2.5x) )
4 Passo Gavia 2640m (Italie, 2007, 2019)
5 Simplonpass 2005m (Svycarsko-Italie, 2007, 2011)
6 Furkapass 2436m (Svycarsko, 2007)
7 Oberalppass 2046m (Svycarsko, 2007)
8 Passo piccolo san Bernardo 2188m (Francie, 2008, 2010, 2011)
9 Passo grande san Bernardo 2423m (Svycarsko-Francie, 2010, 2011)
10 Col de'l Iseran 2770m (Francie, 2008, 2010)
11 Col du Galibier 2645m (Francie, 2008,2009)
12 Col du Vars 2111m (Francie, 2008, 2011, 2021, 2024 (2×))
13 Cima de la Bonette 2802m (Francie, 2008, 2011, 2021, 2025)
14 Passo Rombo 2503m (Rakousko,Italie, 2009)
15 Col de'l Izoard 2344m (Francie, 2009, 2021, 2025)
16 Umbrailpass 2503m (Italie-Svycarsko, 2010)
17 Passo dello Splungo 2118m (Italie-Svycarsko, 2010, 2011)
18 Nufenenpass 2478m (Svycarsko, 2010)
19 Col de la Croix du Fer 2068m (Francie, 2010)
20 Passo S. Bernardino 2065m (Svycarsko, 2011)
21 Passo Torre di Fraele 1800m (Italie, 2011)
22 Passo di Foscagno 2291m (Italie, 2011)
23 Passo Bernina 2328m (Svycarsko, 2011)
24 Livigno Pass 2315m (Italie-Svycarsko, 2011)
25 Montgenevre 1854m (Francie, 2011, 2021, 2024)
26 Passo Sella 2218m (Italie, 2019)
27 Passo Pordoi 2239m (talie, 2019)
28 Passo Falzarego 2105m (Italie, 2019)
29 Col d'Allos 2250m (Francie, 2021)
30 Colle della Maddalena/Col de Larche 1996m (Fr-It, 2021, 2024, 2025)
31 Col de la Cayolle 2326m (Francie, 2024)
32 Col de la Machine 1011m + Combe Laval (Francie, 2024)
33 Col Agnel 2744m (Fr-It, 2025)
34 Col de la Lombarde 2350m (Fr-It, 2025)
ToDo:
prio 1:
Alta via del sale (Italie)
prio 2:
Flüela Pass (Svycarsko, 2383 m)
Albula Pass (Svycarsko, 2312 m)
Grimsel Pass (Svycarsko, 2164 m)
Ostatni:
1 Veleta 2600m (az nahoru se vyjet neda) (Sierra Nevada, Spanelsko, 2010)
2 Pas de La Casa 2400m (Pyreneje, Andorra, 2009)
3 Col d'Aspin 1489m (Pyreneje, Francie, 2011)
4 Col du Tourmalet 2115m (Pyreneje, Francie, 2011)
5 Port de Boucharo 2270m (Pyreneje, Francie-Spanelsko, 2011) az nahoru vyjet nejde, zavalena cesta
6 Col du Soulor 1474m (Pyrenje, Francie, 2011)
7 Col du Aubisque 1709m (Pyreneje, Francie, 2011)
8 Col du Pourtalet 1794m (Pyreneje, Francie-Spanelsko, 2011)
9 Transfăgărășan 2042m (Făgărăș, Rumunsko, 2022, 2023)
10 Pasul Urdele 2145m (Capatanei, Rumunsko, 2022)
ToDo:
Pikes Peak (USA-CO, 4301 m) :D
Stav:
-> Pohon
--> Motor 1.5 (druha verze od MEXu 2009 po repasi 2015), olejovy chladic (MOCAL, 115mm 34 rad.) plus termostat
--> spojka SACHS s lamelou z TAZ1500 (109-150111, 441 270 532 529).
--> ventilator dochlazovani SPAL, trochu mne zklamal, ale nejak to chladi
--> Karburator revize C:
----> komora 25/28 udelana ze zakladu 23/27.
----> hlavni systemy: I st. 140/180, II. st. 160/140. II. st.
----> prechod/volnobeh: I. st. 50, II. st. 70
----> viko SEDR T613, ventil 2mm
----> sytic (tlumitko, tycka, kluisa) dle originalu SEDR T613, tryska 145
--> mereni teploty oleje a vody ridici jednotkou (presnost +-1 st.), sensor domaci vyroby s termistorem EPCOS (kalibrovano)
--> indikace tlaku oleje (VDO set - snimac 10bar + klasicky indikacni budik, presnost +- bota)
--> lpg na hrani a levnejsi jezdeni (1998,2009,2020)
--> upravene sani s implementovanou upravenou starsi verzi mixu pro fel 1.3 (viz. foto)
---> snizeni zastavbove vysky
---> lepsi provoz na beno a hlavne bez der, zpusobenych virenim za puvodnim mixem
---> vestaven delsi vzduchovy filtr z Fiatu Doblo 1.4JTD? (3C1-18900, C 1189 (Mann) )
--> vestaveny modul pro prubezne mereni bohatosti sirokopasmovou LS (Bosh LSU4.2)
--> elektronicka ridici jednotka zapalovani BTZ-III (2007)
-> Podvozek
2004:
--> nova zadni naprava, vyztuzena nova podelna ramena, nova sikma ramena, nove silentbloky, nova pricka
2008:
--> nove kloubove hridele
2009:
--> Predni naprava s chlazenymi kotouci (Saky) a pruzinami 260mm (od PJ) (2009)
2020:
--> Vymena kotoucu - opet za Sakyho typ (upravce wena), vyreseneo zahadne mlaceni
--> Vymena naboju a prednich lozisek
2021:
--> Vymena zadni napravy
--->Osazena puvodni ramena sikma i podelna a pricka (demontovano 2004), podelna vyztuzena, pricka ovarena
--->Nove tlumice (Monroe z sedeho I po 21 letech demontovany)
--->Loziska 21306 (+spacer) a NU205
--->Hridele Kalmar
--->Nove silentbloky
2022:
--> Instalovany unasece kol od paja120
-> vicemene nova prevodovka 5q/3.9 a prislusenstvi (2004, 2009, 2015)
--> servis a serizeni (Wena, 5/2024)
-> Elektro
--> Zastavba BlueTooth gatewaye, k jednotce je mozno se pripojit pres BT z notebooku nebo telefonu (SPP)
--> Elektronizovany pristrojovy stit (krom tachometru - je v planu) (2010)
--> Renovace/vymena predni casti svazku
--> Predratovani hlavnich napajecich vodicu
--> Pridavna pojistkova skrinka na baterii (pritomnost nejistenych dratu vedoucich vsude mozne mne stavala)
--> Doplneno silove jisteni sarteru a alternatoru
-> Karoserie
--> nove zadni okno tonovane na cca 50% nakovenim, bocni na 30% (2007)
--> vymenene predni blatniky (2004, 2016)
--> novy lak 1305 - barva + bezbarvy lak (2004)
--> novy lak 1305 - barva + bezbarvy lak (2017)
--> vymena stropnice (2017)
Poznamkovnik (naplne, spotrebni material, netypicke dily):
Maziva a jiné materiály:
- predni kola SKF LGWA 2
- zadni kola SKF LGWA 2
- svislaky Mogul A00
- vodni cerpadlo SKF LGHP 2
- homokinetaky Millers Hi Mol 20
- motor:
-- Millers Oils NANODRIVE - CFS 10W-60 NT+ (6/2026; 10/2024; 4/2023)
-- Lozisko v klice SKF LGHB 2
- prevodovka:
-- Castrol Syntrans Transaxle 75W-90 (Novy od: 2024, 2017), doplneno 6/2023 2dl
- chladici kapalina G12+
- brzdovka DOT 4 ATE 200 (5/2025)
- brzdy predek - Ferodo Ds2500
- brzdy zadek - Renovak beral
- vzduchovy filtr (longbox) MANN C 1189
- spojkova lamela TAZ1500 (109-150111, 441 270 532 529)
- spojkove lozisko SACHS (02) 3151 812 001
- chladic oleje MOCAL, 115mm 34 rad.
- termostat oleje MOCAL OT/2G
- ventilator dochlazovani vody VA02-AP70/LL-52A
- snimac tlaku oleje 443429021000 Tatra - snad ekvivalent VDO 360-081-030-004C
- indikator tlaku oleje VDO-350010014K
- snimac teploty oleje pro VDO indikátor - interní kalibrační označení 12
- civka Pertronix 60103 (0.3 Ohm, 2.6mH, 60kV)
- pneumatiky: Dunlop Sport Classic 185/70 R13
- palivove hadice dle spec. SAE 30R9
/* - neaktualni -
motor:
-- Castrol Edge TITANIUM FST 10W-60 (6/2021)
-- snimac tlaku oleje VDO 360-023 (0-10bar) + indikator tlaku oleje VDO-350-108 (0-10bar, stupnice PSI) demontaz 6/2023
-- Karburator A: 23.5/26.5 I. st. 130/180 II. st. 160/140 - slouzi jako zalozni nouzovy
-- Karburator B: 26/28 mm z polotovaru 22/24. Puvodne I. st. 130/160 II. st. 155/140. (nasazuje bohate pak prilis chudne) Nalsedne II. st. 145/120. Prechodove/volnobezne trysky lehce zvetseny, prumer neznamy.
- Karburator D: komora 23/27 (T-613 bez uprav). I.st 130/180/50 2st. 155/140/60
predni naprava:
- brzdy predek - Ferodo Ds2500 /* "Renovak" */
Zadni naprava:
- vnitrni lozisko 22205 (zkraceny naboj u kloubu o 3mm)
- pneumatiky: Continental EcoContact 3 185/70 R13
Alpy:
ToDo:
prio 1:
prio 2:
Ostatni:
ToDo:
Stav:
-> Pohon
-> Podvozek
2004:
2008:
2009:
2020:
2021:
--->Hridele Kalmar
2022:
-> Elektro
-> Karoserie
- motor:
- prevodovka:
/* - neaktualni -
motor:
predni naprava:
Zadni naprava:
COL/S136R - komentáře:
23:57:09
11.09.2006
11.09.2006
COL
-> Sniper: drzim palec :o)
23:56:42
11.09.2006
11.09.2006
COL
Namontovany novy airbox s implementovanym mixem (upravena starsi verze pro fe 1.3, uprava zvetsenim vnitrniho prumeru o cca 2.5mm). Airbox viz. foto. Zatim sbiram skusenosti a cekam, az si budu mit cas pohrat s nastavenim. Zatim muzu jen rici, ze to vice saje plyn a srouby musi byt vice utazene, podle ocekavani se to chova mravne na bezin a je nizsi zasyavbpva vyska. Odvetrani je zatim zavedeno na puvodni misto, tj. nyni za mix. Takze plyny, co projdou kolem pistu se chovaji jako EGR :o). Musim vyzkouset jeste verzi, kdy odvetrani vede tesne pred difuzor mixu. Sejmuti hadice odvzdusneni jen mirne rozhodi volnobeh, ale nechcipne to (co by to ale delalo za jizdy jsem nezkousel.)
17:51:43
11.09.2006
11.09.2006
Sniper
no na ty plechy k motoru sem zvědav, mám je taky z motoauto z bakova :)
19:26:05
04.08.2006
04.08.2006
COL
-> FORM: No nikdo se na to moc neptal... a jak to vis ty? :o)
Co mi mel kdo vymyslet na katedre ridici techniky?
17:49:19
01.08.2006
01.08.2006
FORM - zlomená ojnice
-> COL: Tak co ti na katedře řídící techniky zkonstruovali nového? To jsi ani neřekl že jsi taky z FELky....
22:58:41
31.07.2006
31.07.2006
11:28:21
22.07.2006
22.07.2006
COL
-> Max: na benzin, na plyn jednobodova rizena pripust - ale ti "az nekdy" :o)
12:46:28
12.03.2006
12.03.2006
Max
-> COL: no seš fakt dobrej... jen se chci zeptat,to vstřikování plánuješ na plyn nebo na benzín ?
22:34:35
11.03.2006
11.03.2006
COL
-> FORM: chci to mit jako sbernici na kterou by slo povesit vice veci, tim 232 pada. Navic 232, zejmena pri vyssich rychlostech, neni pro takovouhle komunikaci vubec vhodna. A ze zkusenosti vim, ze cim vice nevhodnych prvku a prvku na hranici funcknosti clovek pouzije, tim je vysledek tragictejsi. 485 je docela robustni, ale psat multimaster komunikaci, mne zas tak moc nebavi. Jednoznacne reseni je CAN, ma vhodne elektricke parametry, pristup na medium resi uz radic, zbyva dopsat protokol, je-li ho ovsem treba.
01:26:21
04.03.2006
04.03.2006
-> FORM: Jo jestli ještě sháníš plato, tak jsem jedno viděl nové u nás v mototechně
01:19:30
04.03.2006
04.03.2006
-> COL: Přece jenom bude člověk mít notebook v autě, takže maximálně pár metrů od řídící jednotky, navíc poslední dobou notebooky nějak přicházejí o sériové porty
01:18:36
04.03.2006
04.03.2006
01:13:06
04.03.2006
04.03.2006
-> COL: Nabubřelé? vždyť na to můžeš napojit dva motory a ješte ti zbyde dostatek linek. Ne, je to krásná práce, muselo to stát spoustu námahy, času a peněz, asi ještě stát bude, jinak 485 je sice mocná, ale já bych asi zůstal u staré dobré 232, nebo USB, ale nevím jak je to u něj se zajištěním přístupu k toku dat, kvůli SPI programování, nebo použít převodník na 232 (myslím že se dělaly nějaké FDTI).
23:48:31
03.03.2006
03.03.2006
COL
-> Form: ano, vymyslel jsem to ja. Je to ponekud nabubrele, ale chtel jsem se vynout tomu, ze tam budu muset neco dobastlovat. je tam 2x atmega 128, 512kB zalohovane RAM na data logging, komunikace po rs485 (tlucu hlavou o zed, ze jsem tam nedal CAN, rozbihani multimaster protokolu na 485 se mi dost vlece a uz me to stve), spinany zdroj, funguje to uz od 5.5V, 1xlambda, 5x vstrik, 1x polohove servo, 2x mereni teploty, 2x tlak, 6 analogovych vstupu, 6 digitalnich vstupu, 3x dig vystup, 6x LED, 2x univerzalni rele, 2x koncovy stupen pro indukcni zapalovani s programovatelnou hodnotou proudu do 15A, detektor klepani, RTC, pokus o hardwarovy interpolator polohy setrvacniku....
09:32:44
01.03.2006
01.03.2006
-> COL: vidím nějaké hradlové pole, flashku, ten atmel je AVR?
09:30:35
01.03.2006
01.03.2006
-> COL: Návr toho EQU je kompletně tvůj? Pak skláním hlavu před velkým obvodářem....
14:31:48
11.01.2006
11.01.2006
Petr P
Obdivuju práci na ECU a trpělivost při vývoji..
Já jsem vývoj vlastní zavrhl a pořídil něco už vymyšleného. www.vems.hu/products.html Na jejím vývoji se stále pracuje.
Něco málo mám tady u auta..
Ty konektory na fotce jsou impozantní.
Já jsem vývoj vlastní zavrhl a pořídil něco už vymyšleného. www.vems.hu/products.html Na jejím vývoji se stále pracuje.Něco málo mám tady u auta..
14:30:05
11.01.2006
11.01.2006
Petr P
11:36:02
23.12.2005
23.12.2005
Pavel P@nkáč
-> COL: ty jo taky čumim na tu jednotku seš fakt machr
22:45:39
22.12.2005
22.12.2005
Max
-> COL: ta jednotka je zajímavá....seš husťák :-) V čem to programuješ ? Jo a jak je to velký rozměrově (ta jednotka) ?
COL/S136R
